Message 11 of 17
Re: Can not connect using to-link Archer VR600
Is the DSL light lit on the VR600? I haven't got a VR600, but I'm guessing there is a DSL led and an Internet LED.
Message 12 of 17
Sorry, yes the DSL Synchronisation light is on
Recognised Expert
Message 13 of 17
& the Internet LED OFF?
Do you need to Set Up an IPv6 Connection for BT BB?
___________________________________________________________________________
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on left hand side
Message 14 of 17
Thanks for all the advice. I had to quit last night as my heating is controlled by my internet connection and it was getting cold! I’ll try again tonight to see if I have any better luck.
Message 15 of 17
So tonight I reset the router back to factory settings and set it up via the wizard using the settings in my first post... and it works immediately! No idea what was going on last night but thanks to everyone for their help.
Message 16 of 17
Message 17 of 17
Result!! Thanks for updating the thread.
