pibrom
Message 1 of 4
Can only connect with wps.
My HH5 died and has been replaced with a HH6.
All seems fine except one mobile (Moto G) will only connect with use of wps button.
It connected perfectly well on the HH5.
HH6 firmware up to date, am I missing something obvious?
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Can only connect with wps.
@pibrom Can you try turning off smart set up to see if this helps?
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
pibrom
Message 3 of 4
Smart set up was off by default.
Very strangely without my changing anything the mobile has started connecting to wifi normally.
Jim3
Message 4 of 4
Strangely enough my 2 sky boxes would only connect using WPS most other devices iPad mobiles automatically picked up on the guest logon that they were already setup on
I am using my own router Asus RT-AC68U
