TB2020
Message 1 of 3
Can't Connect Alexa Dot to BT Hub 6
My Alexa Dot was disconnected owing to work being done at the house, but after 2 weeks and plugging it back in it now won't connect to my Hub6 no matter what I do. I have ensured the device is close to the Hub. I've turned the hub  and Echo Dot off and back on. I've checked online to see if my Alexa Dot is in the device list (it isn't). All other devices work fine but the Dot just keeps saying Can't Connect To The Internet. Any help gratefully received.
2 REPLIES 2
PaddyB
Moderator
Moderator
Message 2 of 3
Re: Can't Connect Alexa Dot to BT Hub 6
Hi @TB2020,
Thank you for posting. I'm sorry you're having problems connecting your echo dot.
Can you make sure the smart setup has been turned off on your hub?
how to turn of Smart setup
PaddyB
TB2020
Message 3 of 3
Delighted to say I sorted this. For whatever reason, it was locked in MUTE but I didn't work out that's why it was showing the red light and unable to connect.
