Newbie
Message 1 of 18
Can't access a website - HELP!
Hi all
I need to access the following website but for some reason it won't work on my BT infinity broadband. BT support as usual is pants.
website is www.gosforthacademy.org.uk
Using the same devices (phone, laptop, Ipad) we can access this on other ISP's (sky, virgin, even 4g) just not via BT broadband.
Have been passed over here by BT support as they don't have a clue.
I've enabled parental controls (was off previously) and added the website in on the whitelist - still no-go.
Anyone else able to access the website?
Ive reset my hub 5 and checked multiple browsers. again, works fine outside bt broadband just on with bt broadband.
Ready to change ISP 😞
17 REPLIES 17
Expert
Message 2 of 18
Re: Can't access a website - HELP!
Hi @davem48
Welcome to the Community!
I think it's hosts you need to change, not ISP. Or at least the configuration of your site.
I still had problems, even when loading off BT.
Two(!) of my usual page-speed test utilities failed to load the site at all. Perhaps speak to your host support (if available) or web developer.
Thanks,
AJ
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
Message 3 of 18
Distinguished Guru
Message 4 of 18
@davem48wrote:
Hi all
Hi, welcome to the forums.
The issue is with the site I'm afraid. I've tried various accesses, including changing DNS to use Googles - and no available.
How long has this been happening?
Strange that the helpdesk sent you here, which is good news as at least they know about it - but they should have been able to at least give some detail about failure to connect.
There are many other websites hosted on the same IP address, and trying to access a couple of them also fails.
Is the site actually working fine via the other connections you mentioned, or do they just show a website which may be cached?
Distinguished Guru
Message 5 of 18
I don't think it's the OP's site ...
Sage
Message 6 of 18
@Andy_N wrote:
@davem48wrote:
Hi all
If the issue were the website then the problem would appear across ISP's. It doesn't so its not a website issue.
Expert
Message 7 of 18
@pippincpwrote:
@Andy_Nwrote:
@davem48wrote:
Hi all
The problem does occur across ISPs, at least for me. I'm pretty sure it's the host, myself.
Expert
Message 8 of 18
Neither, after reading your post 😊
Now, I too, have tried to access sites on the same IP with similar issues.
Newbie
Message 9 of 18
Hi all -thanks for the quick responses. I'm not sure it is the host site. This is a school sitwe my kids need to use for homework. Other friends of theirs on virgin, sky, talk talk, etc can access the site fine. Even on 3/4g the site opens fine. the issue is only with BT.
Recognised Expert
Message 10 of 18
I can open that site from your link OK, maybe it was just a temporary thing?
