Rom
Message 1 of 1
Can’t connect IP security camera to wifi
I’ve bought a SV3C camera and use CamHi app on my iPhone.
i follow instructions for set up, with an Ethernet cable all is good and camera installs fine. When I try to connect with WiFi, after the point it asks me for the WiFi password, it tells the password is incorrect.
I had the exact same faults on a different camera which I sent back, but it seems the problem is with my WiFi ?
My WiFi is split and I am trying to connect to the 2.4 GHz, I’m using HH 4
the instructions also describe how to connect by ‘AP mode’. This works, though I don’t know what it is, however I don’t think will work when I leave the house. I want to monitor the camera with my phone when I’m away from home
thanks for any help
