PaulaC
Newbie
Message 1 of 20
Can't connect Kindle Fire HD to BT Home Hub 3
I've just bought a Kindle Fire HD and can't get it to connect to my BT Home Hub (I think it's a 3) I have an ipad and iphone and they are connecting fine....help?
19 REPLIES 19
Message 2 of 20
Re: Can't connect Kindle Fire HD to BT Home Hub 3
See link for connecting an Android tablet. It should be more or less the same for a Kindle Fire.
http://bt.custhelp.com/app/answers/detail/a_id/44480/c/346
Make sure you use the wireless passkey found on the label of the hub and not the admin password or your email password.
scott_johnston
Message 3 of 20
PaulaC
Newbie
Message 4 of 20
This is exactly what I've done, numerous times but I'm getting an error "DHCP Error - could not connect to internet" I'm nearly pulling my hair out! Thanks for taking the time to send the link though
PaulaC
Newbie
Message 5 of 20
Cheers for that link, it's the Home Hub 3 I've got
Message 6 of 20
Try a factory reset of the homehub by pressing a pin into the recess button on the rear for about 20 seconds. While it is restarting "delete/forget" any connection to the homehub on the Kindle then restart the Kindle. Once everything has restarted try remaking the connection.
scott_johnston
Message 7 of 20
go to wireless and tap your wifi network and box should appear detailing status,link speed, Ip address etc. Does it give you a IP address
PaulaC
Newbie
Message 8 of 20
i've already tried resetting the router twice but thanks
PaulaC
Newbie
Message 9 of 20
Yea I have my IP address.  I've tried changing a setting from b/g/n to just b/g temporarily as this was one answer on another site but this didn't work either
Message 10 of 20
Did you try the procedure as I outlined it?
