Message 1 of 3
Can’t connect Solar inverter to Wi-Fi can I disable firewall?
2 REPLIES 2
Message 2 of 3
Re: Can’t connect Solar inverter to Wi-Fi can I disable firewall?
It won't be your firewall preventing it. Try turning off the 5Ghz wifi temporarily until inverter connected and then restore it once it has.
Much better to connect it via Ethernet cable in any case.
Message 3 of 3
No Ethernet available already switched off 5g no better app says dongle connected but inverter off line
