IanM1
Message 1 of 2
Can’t connect to BT through WiFi when abroad. 4G works OK
I was in Spain and now in Germany. I connect to WiFi and all goes fine at first but next time I try to use I get a failure to connect to BT message. If I switch off WiFi, 4G works fine. All other apps. Google etc work fine with WiFi. Only problem is BT.
1 REPLY 1
imjolly
Message 2 of 2
Re: Can’t connect to BT through WiFi when abroad. 4G works OK
if using the BTWIFI app abroad then you are using the BTFON connection in UK but it is the FON part which you are trying to connect to in other countries    Problems connecting  are common as you are connecting to other FON partners but the problem is nothing to do with BT  the problem is with the other country FON partners
