Babs99
Message 1 of 5
Can't connect to works VPN
As the prospect of working from home is looming I thought I would check my set up & although it worked okay a short while ago - I am unable to connect now.  We use Pulse Secure for work, and it just fails to connect. I have read through previous comments on the forum and have turned off Smart set up also changed the setting for Port clamping to On. But it still fails.
Work said that for BT users you have to change the Web preferences  but the link doesn't work
http://preferences.webaddresshelp.bt.com/selfcare/
Any idea on how to change them or any other suggestions?
4 REPLIES 4
Matt-S
Moderator-Retired
Message 2 of 5
Re: Can't connect to works VPN
Hi @Babs99
Welcome to the Community and thanks for posting.
Sorry that your having problems connecting to your work VPN.
Are you currently connected to your home BT Broadband connection?
Here is some more info that might help.
Let me know how you get on 🙂
Matt
Babs99
Message 3 of 5
No have gone into work today - but I did find that info page you have sent me but when I clicked on the BT Web Address Help Preferences page whilst connected to my home BT it just took me to another help page & then another - but not actually to the page I need to update.
I will try again tonight & hopefully chat room will work as it wasn't yesterday morning
Babs99
Message 4 of 5
All sorted now - not sure what did work but must have been either turning off Smart Setup as can't get to this link http://preferences.webaddresshelp.bt.com/selfcare/  - it doesn't take you anywhere apart from circles
kevthepuss
Message 5 of 5
Thanks for the tip about disabling Smart Setup Babs99, I was having the same issue having just changed from a Home Hub to a Smart Hub, Pulse Secure VPN was no longer connecting. I believe I also needed to enable Port clamping on the VPN page.
Tags (1)
