joebhoy
Message 1 of 4
Can u Script firewall changes on smarthub
I want to turn off/on port rules frequently and the interface is a bit of a pain for doing it manually. Anyway to script these changes at all ?
3 REPLIES 3
Message 2 of 4
Re: Can u Script firewall changes on smarthub
Not as such, but I think you can save the config so just create a number of different configs to reload.
Jonkarra
Expert
Message 3 of 4
Nothing official although I'd guess there is some structure to how rules are created via the web interface you might be able to do it via HTTP POST commands. Word of warning though the firmware can change without notice and your script will suddenly stop working.
sjonez
Message 4 of 4
If you have UPnP enabled on your hub then you can script rules using that as it's the same universal standard across all routers. There should be plenty of command line tools or C#/Java classes to enable scripting.
e.g. here's a java one: https://upnp-portmapper.sourceforge.io/
