Message 1 of 63
Cannot access my own uk website except via VPN
Hi
have set up a new website for a local charity on Linux hosting (won’t mention hosting company) after  provisioning couldn’t access the site using any device ( iOS or win 10) on my network Wi-Fi or Ethernet (error 404 and nginx under the 404 )
Could access the site solely via mobile data
so cleared every cache flushed DNS, changed DNS servers reset networking  - still no joy
tried via VPN - bingo site accessed
so reset router to obtain a new IP address ( a new one was allocated) - no joy
Ran my VPN and site seen
I can access any other site without the VPN
the hosting company flatly denies they’re blocking the site which seems logical, so the only assumption I can make is somehow BT is blocking that particular website IP address
does anyone have any ideas on how to get BT to unblock a specific address please ?
thanks in advance
62 REPLIES 62
Message 2 of 63
Re: Cannot access my own uk website except via VPN
It could be a DNS issue - what is the website address?
Fibre 2 Unlimited using EE Smart Hub 2 with EE TV Box Pro (UHD/HDR) in IP mode.
Message 3 of 63
thanks for replying
www.formbycivicsociety.org.uk
or do you want the IP address ?
it’s fine with VPN ( set as UK location) turned on
turned off no access no matter what browser I use including freshly downloaded and installed opera
Message 4 of 63
@Unbelievable
On my PC using google dns servers no problem, on my iphone using OpenDNS (from my router) can't get it but over BT 4G no problem.
Any help?
Message 5 of 63
Hmmmm
even weirder than my access
4G yes
anything via router unless using VPN No, tried google DNS on my Ethernet adapter yesterday - no joy
can try again later
Looks like a DNS error somewhere ☹️ But such a weird one
Looks as if dns in HH6  is permanent
thanks - will keep trying - concerning that OpenDNS isn’t working
Message 6 of 63
Using BT here it is not found - but works fine on VirginMedia.
Message 7 of 63
It’s definitely a BT problem, just had a neighbour ( Bt isp) check the site and they’re  getting the 404 message
BT please fix
Message 8 of 63
@Unbelievable For your site I get "An invalid set of parameters has been specified in the url."
Message 9 of 63
The link in the post isn't a direct link to the site in question
Message 10 of 63
@Unbelievable But when I type the address myself I get there. formbycivicsociety.org.uk
