Message 11 of 63
Re: Cannot access my own uk website except via VPN
It wasn’t a direct link - just the name of the website
Message 12 of 63
But it appears on the forum as a clickable link.
Message 13 of 63
However, MS Edge offers a warning that the site is "not secure" - not to enter passwords or credit card numbers.  I use onedotcom and wordpress and think I had this sort of thing with them but there was a plug-in that sorted it.  Probably not a BT problem but either over-zealous browsers or some site design issue.
Message 14 of 63
Message 15 of 63
the hyperlinking is not of my making
the site address is http://www.formbycivicsociety.org.uk
A mate on ee can access via google search and clicking the link
I’ve just checked the above link by copying and pasting into a browser and whilst the VPN is active the site is accessible - turn VPN off and 404
I’m checking with hosting company just in case they are filtering/blocking Bt  addresses
Message 16 of 63
Because it is an HTTP site rather than HTTPS.
Message 17 of 63
@licquorice yes - that was what I had to fix.
Message 18 of 63
I get a 404 using either BT's DNS or Google's DNS. Ok via O2 4G
Message 19 of 63
Yep that’s the issue any access via BT as ISP gives 404
Message 20 of 63
Possibly BT is picky about it being an insecure site. Does your hosting company not offer SSL certs for sites?
