Message 21 of 63
Re: Cannot access my own uk website except via VPN
@licquorice but I can see the site - and I'm on BT.  The only slight oddity my end is that I don't use a HH - just an ECI modem and a Deco M5 system.  For my own sites I did have to install SSL.
Message 22 of 63
It worked fine until Saturday afternoon when I switched to Linux hosting for the Wordpress site - it’s a local charity so funds are tight (and we don’t need HTTPS) and 2 other sites I run through the same hosting company on Linux hosting are accessible, no VPN required and are HTTP - no hiccups
Message 23 of 63
I’m on a HH6
Message 24 of 63
@Unbelievable  The hosting company I use for our village hall (IONOS) doesn't charge extra for HTTPS
@gspearson  What DNS servers are you using?
Message 25 of 63
@licquorice I don't know!  (Don't tell anyone).
Message 26 of 63
@Unbelievable  Ok, just tried Open DNS and that works fine so not a BT problem, a DNS propagation problem.
Message 27 of 63
Ok thanks for update I’m not a networking expert
so dns propagation problem ? How do I fix it ?
so how do I use OpenDNS with a HH6 ?
Sorry the thread is that long I’m not certain who has what now - do you have a standard setup with HH or bespoke router
Ive been into the advanced settings HH6 and can’t change the DNS settings
If it’s not a BT problem with standard setup then why is my mate ( 1 door away) unable to connect to the site whereas another mate on EE can
Message 28 of 63
Ok I’m with Fasthosts and they do charge
Message 29 of 63
You can't fix it, it's down to your hosting company. You can't change DNS server settings on BT home hubs. They can be configured on third party routers or on individual devices if connected to a BT hub.
Message 30 of 63
Thanks been researching after your reply
so if it’s a DNS propagation issue it should correct itself in time when records are updated ?
still confused as to why it’s only standard BT setups which can’t access the site ( other ISPs can) but even with my standard setup once I go through the VPN it’s ok doesn’t that indicate it’s something to with BT ?
I assume the VPN will use its own DNS
down the networking rabbit hole ☹️
