Message 31 of 63
Re: Cannot access my own uk website except via VPN
It's because the BT (and Google) DNS servers haven't been updated yet, whereas Open DNS and the servers other ISPs use have. Hopefully it should just be a matter of time before the servers get updated.
Message 32 of 63
Thank you 👍
Sounds logical - I’ll keep checking over the next few days
I may be back 😉
Message 33 of 63
@Unbelievable  Site now accessible with both BT and Google DNS servers.
Message 34 of 63
absolutely no difference
have used 'clean' pc did ipconfig /flushdns
set the network adapter to opensdns servers for IPV4
rebooted
still no change
had my daughter check other end of the country via her wifi and site loads fine on mobile (connected to plusnet router)
no access from ipad or any PC - exactly that same since saturday afternoon ☹️
are you using a HH6 or smart hub or a different router ?
Message 35 of 63
Smart hub 2, but router is irrelevant.
Just tried the site again and getting a 404 this morning
Message 36 of 63
I can still see it. I also did a Google search, it came up in the hits and I got in that way.Formby.JPG
Message 37 of 63
ah ok - that's a blow
someone mentioned that they were using a non BT router and could access the site hence my suspicions about a standard BT setup
I've had confirmation from the hosting company that they do not block/filter any incoming IP addresses
do you know of any way I can escalate this within BT ?- just the weirdest problem I've ever seen
Message 38 of 63
@Unbelievable I don't use a BT router/HH - just a modem and a Deco M5 set - best wifi I've ever had.
Message 39 of 63
unfortunately that is showing the initial wordpress page from mid saturday afternoon and the links are the 'old' ones
I can see all that but what I can't do is click on the google link (without my VPN) and gain access to the site or even have the site load it just returns 404
Message 40 of 63
can you open the site ?
