WaltJabsco
Message 1 of 7
Cannot connect to Home Hub Manager
Cannot connect since I renamed my 2.4 GHz and 5 GHz channels.
I used a space and bracket which I don't think works - i.e. BTHomeHub (2.4GHz)
However I cannot now access the Home Hub Manager to rename the networks.
I have tried to access via:
api.home
192.168.1.154
bthomehub.home
6 REPLIES 6
scotta1980
Message 2 of 7
Re: Cannot connect to Home Hub Manager
try 192.168.1.254
WaltJabsco
Message 3 of 7
As stated above I've tried that plus the other two routes
Distinguished Guru
Message 4 of 7
I suggest you try a factory reset of the hub
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-home-hub-to-its-factory-...
If not, I'll try again 🙂
WaltJabsco
Message 5 of 7
sorry just re-read and you've suggseted 254
it was a typo - I've already tried that not 154
Message 6 of 7
Have you tried connecting with an Ethernet lead?
WaltJabsco
Message 7 of 7
I eventually fully reset the Home Hub and was able to access Home Hub Manager again.
Couple of learnings:
1) When splitting and renaming the 2.4 GHz & 5 GHz networks do not use spaces or brackets.
2) To properly reset the Home Hub, need to keep the paper clip in the reset button until the orange light shows, rather than taking it out after 15 seconds
