JohnBergqvist
Message 1 of 8
Cannot get IPTV to work on ASUS/ROG GT-AC5300 Router with DrayTek Vigor 130 Modem
I'm trying to get IPTV to work on my YouView Box now that i've switched to an ROG GT-AC3500 Router (with a DrayTek Vigor 130 Modem), but no matter what guides I follow, I can't seem to get it working.
I have enabled bridging mode on the 130 as described here: https://www.draytek.co.uk/support/guides/kb-vigor-130-bridge
(For those of you who can't see it: on the Vigor, I go to [Internet Access] > [MPoA / Static or dynamic IP], on that page, select Enable)
Then I have my router itself configured as follows, first WAN, then IPTV:
What am I doing wrong? It doesn't matter what I set the IPTV STB Port to, although the YouView box is physically plugged into port 1 on the router.
The "IPTV/ VoIP Port Settings" dropdown is either LAN1/LAN2 or "LAN5/LAN6", those are the only 2 options available.
The options in the "IPTV STB Port" dropdown are: "None", "LAN1", "LAN2" and "LAN1 & LAN2". In here, LAN1 and LAN2 are replaced by 5 & 6 depending on which option i've chosen in the "IPTV/VoIP Port Settings" drop-down box.
7 REPLIES 7
Devon_Dave
Distinguished Guru
Message 2 of 8
Re: Cannot get IPTV to work on ASUS/ROG GT-AC5300 Router with DrayTek Vigor 130 Modem
Check this link.
https://community.bt.com/t5/YouView-Boxes/Using-a-3rd-party-router-for-Multicast/td-p/1048582
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
JohnBergqvist
Message 3 of 8
Unfortunately the steps described there (especially for the ASUS one) don't match my router exactly. Look at my screenshots above, and you'll see I don't have an "IGMP Snooping" option.
Keith_Beddoe
Message 4 of 8
This page mentions IPTV
https://www.eteknix.com/asus-rog-rapture-gt-ac5300-enthusiast-router-review/6/
Look under "Wired Network"
JohnBergqvist
Message 5 of 8
Yes, I know the router has generic IPTV functionality, but what settings in particular do I need to get this specific router to work with BT's IPTV?
imjolly
Message 6 of 8
have you tried reading through the ASUS forum as you are more likely to find an answer there
Liam_
Recognised Expert
Message 7 of 8
If you haven't already got it sorted out have a look at this part of the router config.
Select the port you have the TV on then enable the IGMP parts that are disabled in the image.  I don't have an Asus nor use IPTV but it seems the logical choice of settings.
JohnBergqvist
Message 8 of 8
If you had seen the screenshots I had posted of the same screen on my router (latest firmware), you will see that I do not have those options available.
