sukstr
Message 1 of 2
Cannot reset password
By accident, I hit the reset button on my HomeHub5 (or I think I did).
I now have the message about Too Many Login Failures.
"As a security measure, access to your BT Hub Manager has been locked for minutes. "
NB it doesn't tell me how many minutes.
I have attempted to use the password over-ride to set a new password, but gives me a 404 when I submit and makes no difference (yes, I have done the "press WPS key for 15 seconds thing).
1 REPLY 1
Message 2 of 2
Re: Cannot reset password
you would need to press the reset button on the back and hold to reset the password so unlikely you did that by accident  either wait a few hours and try passowrd again of reset it back to factory settings using the recessed button on the back
