Willcop
Message 1 of 3
Cannot see wi if discs on app
I have complete wi if with 3 discs and smart hub 2. They all appear to be working with blue lights on however when I go into the “wi-if network” page on the app to check it wants me to set up my smart hub on the next page. whilst all the discs and hub seem to be working I would like to be able to check the signal strength and remember I used to go under wi if network and see them. I am concerned that if I press the start smart hub set up button, I will mess the system up. Does anyone know how I can bring up the disc information ?
2 REPLIES 2
RobbieMac
Moderator
Moderator
Message 2 of 3
Re: Cannot see wi if discs on app
Hi @Willcop
Welcome to the Community and thanks for your post!
Sorry for the confusion.  Don't worry, once you have everything set up you won't cause any issue going through the app.  It may ask you to set up and enter the admin password again but after that you should get the info you're looking for.
Post back and let me know how you get on.
Cheers,
Robbie
Willcop
Message 3 of 3
Thanks Robbie. I have tried that and I can now see the discs and all is working ok.
