GPR
Message 1 of 4
Cat 5e or Cat 6
Hi, I have just bought a laptop with Windows 10 pre installed and the wireless connection keeps dropping. [ I am 10 feet away from HH5 in the conservatory]
I never had or still do not have a issue with Windows 8 wireless using my wifes laptop dropping in the conservatory.
I have decided to run a ethernet cable from HH5 to conservatory through the kitchen.
I would like to use the best possible ethernet cable for no interference so is Cat 6 the better of the two ?
3 REPLIES 3
Message 2 of 4
Re: Cat 5e or Cat 6
for a distance of 10' it won't make any difference
Message 3 of 4
Re: Cat 5e or Cat 6
Yes.
Message 4 of 4
Re: Cat 5e or Cat 6
have you checked the driver for your wireless card is up to date from manufacturers website
have you split the networks
Split the networks
