Lord_D
Newbie
Message 1 of 5
Changing SSID
Hello
BT is changing my HomeHub (V6) as it has become faulty. Obviously the new Homebub will arrive with a new SSID - my question is can I apply the old SSID (from faulty router) to the new one? I know you can change SSID names per se, but can I attach an old router's name to a new one? They will both be V6 routers.
This is bourne out of lazyness and not wanting to get all the networked equipment re-configured.
Many thanks
David
4 REPLIES 4
conrad
Recognised Expert
Message 2 of 5
Re: Changing SSID
Yes you can assuming you are referring to the wireless SSID. When you split the 2.4 and 5 networks you can rename the networks so just use the current ones in use as well as the current wireless code.
Not so sure about a wired connection but I think the links are generated by the computer so if the wired network is called WWWW it remains that for anything currently connected to the computer regardless of what router is used.
Lord_D
Newbie
Message 3 of 5
Re: Changing SSID
Thank you for the response - it makes sense. I will try it as soon as I receive the new router - in a few days and I will post the results.
Cheers again
Message 4 of 5
Re: Changing SSID
I have done exactly as you intend and it works without a problem bothe wired and wireless
Lord_D
Newbie
Message 5 of 5
Re: Changing SSID
Many thanks for your reply too - glad to know it works!
Appreciated.
