ramyen
Message 11 of 16
Re: Chromebooks no longer connecting to internet
Anonymous
Not applicable
Message 12 of 16
You could try setting your mobile phone up as a wifi hotspot and see if you can connect through that
gg30340
Message 13 of 16
See message 4 and 5
Anonymous
Not applicable
Message 14 of 16
I don't know the model but I'm guessing that it doesn't have an ethernet port. Your work network will presumably only allow domain PCs' so that was never going to work, do you know someone who might let you try logging on to their home network? If not then for the sake of £10 or so you could buy a USB WiFi dongle, that should eliminate your network adapter
gg30340
Message 15 of 16
The OP said he tried logging onto his works guest network so I don't understand why you said "that was never going to work".  Is the purpose of works guest networks not to allow non domain computers to connect?
Mark67
Message 16 of 16
same problem,same attempted solutions
have spilt 3g/5g, powerwashed and reset , powerwashed chrome books..deleted all downloads,..yet still these dont connect other lap tops connect tohe hub....
only thing that worked for me was to reset the BT hub.
which involved pressign a button on the back of the hub....switching on and ff dorsnt work.
i now have to do this every month or two
takes 5 minutes
Tags (1)
