steveslinger
Message 1 of 5
Cisco Any Connect Client fails with new BT HUb
I connect to the office network via VPN  using Cisco AnyConnect client.
Recently switched over to BT Broadband and not now able to connect - DNS resolution errors and timeouts.
Other devices non VPN work fine.
Already switched off Smart Setup but that failed to help
Any help gratefully received.
4 REPLIES 4
Anonymous
Not applicable
Message 2 of 5
Re: Cisco Any Connect Client fails with new BT HUb
No problems connecting before you switched to BT?
To start with, try rebooting your machine.
Failing that, try turning on Port Clamping:-
Using a browser, navigate to 192.168.1.254
Click Advanced
Click Broadband
Click the VPN tab
turn on port clamping.
steveslinger
Message 3 of 5
Thank you i will try that tbis afternoon 🙂
steveslinger
Message 4 of 5
Hi - The port Clamping didnt solve the issue.
Im getting the following :
"unsuccessful domain name resolution"
Ive used my mobile hotspot to connect and that works fine!
Help!
Anonymous
Not applicable
Message 5 of 5
Seems this is a common fault, I've copied and pasted the answer marked useful by 5 others from
https://community.cisco.com/t5/vpn/the-vpn-connection-failed-due-to-unsuccessful-domain-name/td-p/24...
"the anyconnect.xml file had become corrupted, meaning the format of the file was no longer usable by the VPN client. Connecting to another region (different set of VPN HEs) caused a new file to be downloaded, and then we were able to connect to the original HEs. We don't know why the anyconnect.xml file became corrupted, but this fixed the problem in all cases."
