Johnaliuk
Newbie
Message 1 of 4
Cisco AnyConnect VPN Issues
I keep having issuing connecting my work laptop (a Dell) to my work’s VPN (via Cisco AnyConnect). When attempting to login the certificate becomes corrupted resulting in AnyConnect dropping into a loop of disabling then attempting to repair the VPN connector.
This has begun happening since switching to BT.
Has anyone else encountered this? Any known issues?
Tags (1)
3 REPLIES 3
Message 2 of 4
Re: Cisco AnyConnect VPN Issues
Welcome to this user forum. @Johnaliuk
Try turning Smart Setup off.
http://bt.custhelp.com/app/answers/detail/a_id/44328/~/switching-smart-setup-on-and-off-on-the-bt-ho...
Make sure you are opted out of Web address Help.
http://preferences.webaddresshelp.bt.com/selfcare/
Johnaliuk
Newbie
Message 3 of 4
Thanks for the quick reply! I shall give that a whirl!
Message 4 of 4
@Johnaliuk
Has your issue ben resolved?
