LapsedPacifist
Message 1 of 5
Coming back to BT - question about adapters
Good afternoon all
Sorry if this has already been answered before...
We're coming back to BT, I think we have fiber 1 (but am having a difficult time logging into my bt account to check... Every time I do, it redirects me to my email, on the PC it tells me that I've had too many unsuccessful attempts and to try again in 15 mins...)
My question is this... I have this box as the access point to the phone line etc.
Previously, I can't remember the setup, other than that we had a white box (bt openreach box) that the line connected to, which then connected with the bt hub.
This time there is only the hub... I tried connecting an adsl filter to the phone line in the box (see pic) - and both phone and hub to this filter. Phone worked fine, but the hub wouldn't connect to the Internet.
I then connected the hub directly to the box, everything worked fine.
My question is this - do I need the filter for the phone line?
Thank you in advance!
4 REPLIES 4
Keith_Beddoe
Message 2 of 5
Re: Coming back to BT - question about adapters
No, the phone outlet is already filtered. The home hub is now connected to the correct point.
LapsedPacifist
Message 3 of 5
Thanks for the quick response!
Does that mean that the phone line doesn't need a filter either, and I can ignore it?
Kind Regards
licquorice
Message 4 of 5
Correct, you no longer need a filter.
imjolly
Message 5 of 5
the rj11 cable which connects to hub looks to be pushed a long way into socket and will be difficult to extract
