Newbie
Message 1 of 1
Compatibility of BT Bus Hub6 with EnGenius ENS202EXTv2n
Having just had a second BT fast broadband line installed exclusively  to extend BT Broadband by using an EnGenius Access Point ENS202EXTv2 via ethernet, I cannot get it to work despite correctly configurating the access point.  When set in the alternative  Extender mode the EnGenius does not show up on the network at all. I want to use the EnGenius as an access point because it will permit multiple users. I have read that a switch might be the clue. I do not know what switch to use whether it will be compatible and what can be done to solve this problem. Does anyone have any constructive ideas.
