Message 1 of 3
Complete Wi-Fi ethernet set up
Struggling to find this exact question with an answer while browsing the forums.
I have just had fibre internet set up in my house.
The router is downstairs however I need a wired ethernet set-up upstairs in my office.
I looked at complete wifi as an option however before I spend the money on it I'm hoping I can get this question answered.
Can I connect the Wi-Fi disc to the main hub via WPS, and then run an ethernet cable from the disc to my PC?
Many Thanks in advance for any help!
2 REPLIES 2
Message 2 of 3
Re: Complete Wi-Fi ethernet set up
Yes, or alternatively you could use powerline adapters.
Message 3 of 3
Thank you for the information, will make the upgrade!
