Kevinff
Message 1 of 17
Computer cant connect to 5ghz band
Hi there, wondering if I could get some help with this.
My PC doesn't seem to be able to connect to my 5ghz band.
I tried removing most my devices from the 5ghz band to reserve it for my PC.
But it always says it cant connect. My partner can connect to 5ghz fine with their PC, but even when their PC is switched off mine cant connect.
Ive just started working from home and have to use cisco VPN, it works fine for work, but when its my day off and I disconnect from VPN, my computer seems to struggle on 2ghz to watch twitch and play games online.
Ive updated my network card but still no good.
Any advice for my situation? would port forwarding or UPnP help in the hubs settings?
Thanks.
16 REPLIES 16
imjolly
Message 2 of 17
Re: Computer cant connect to 5ghz bands
Can your computer 'see' the SSID of the 5ghz network or it can see the network but won't connect when your enter the password
which hub version are you using? As long as not the SH2 have you tried splitting the networks.
Kevinff
Message 3 of 17
The smart hub I have is the BT Smart Hub Original  <-- see picture
My computer can see the network, it already knows the password, but when I click on it to tell it to connect to the 5ghz, it just says 'cant connect to network'
Yes, I split the networks so they appear as 2ghz and the 5ghz one.
Thanks.
Tags (3)
imjolly
Message 4 of 17
have you tried a factory reset by pressing recessed button on back and holding 20/30 secs till lights flash
when it restarts you need to turn off smart setup and split networks again.  see if it will connect now
Kevinff
Message 5 of 17
Id like to add, this only happens when im next door in the living room, if im in my home office 5ghz works fine.
Im seperated by one wall in each room, and in my office where it can connect im probably 2 metres away from router and in the living room and im about 3 metres away from router and cant connect.
Ive turned the router off and on again a few times, ive not power cycled it yet though.
licquorice
Message 6 of 17
If other devices can connect ok it would appear to be an iffy wireless adapter in your PC.
imjolly
Message 7 of 17
so you can connect to the 5ghz network just not when you are further away from router  the 5ghz network does not cover as far and any think in-between you and hub will restrict the 5ghz signal hence why 2.4ghz covers a wider area and is connecting without a problem
Kevinff
Message 8 of 17
Thanks for that, do you think paying the extra £3 for the BT wireless spot will help in that room to connect to the 5ghz?
Keith_Beddoe
Message 9 of 17
Why not just stick to the 2.4GHz band when you are out of range?
Wireless extenders will not help unless the extender itself can connect to the 5GHz band in that room.
gg30340
Message 10 of 17
Try uninstalling the wireless card and re-start your PC. It will re-install when your re-start your PC.
If that doesn't help, a cheaper option than a BT wireless hotspot would be to buy a dual band wireless dongle for a few pounds and install that on the PC after turning off the onboard wireless card. If that works OK you know its a faulty network card and can either replace it or just keep the wireless dongle connected.
