rayjon
Message 1 of 2
Conect to Samsung Smart TV
Could anyone help, I have hub3 Conected to Desk top computer via cable, I use wireless conect to Laptop in louge,
I use wireless in longe to smart TV, problem is when browser in TV home web page is MSN, how to change home pagt to BT home page, the TV is a Samsung 55" smart TV.
Thanks for reading this message and any help you can give.
Tags (1)
1 REPLY 1
Message 2 of 2
Re: Conect to Samsung Smart TV
I would imagine you would change it in he same way as you would on a computer. Open the BT home page then do to the Tool menu at the top of the page and scroll down to Internet Options. In the General Tab you should see "Home Page". Click "Use Current" click apply and OK.
If that doesn't work you will probably find the answer on a Samsung TV forum.
