randelld
Message 1 of 2
Configure a Draytek Vigor 2860n VDSL2 router for BT broadband
Hi, I have been lucky enough to get hold of a Vigor 2860n VDSL2 router.
I am led to believe that this will work with BT fibre broadband and that I do not need to add a modem.
Can somebody be so kind as to give me the connection settings please.
Many Thanks
1 REPLY 1
Keith_Beddoe
Message 2 of 2
Re: Configure a Draytek Vigor 2860n VDSL2 router for BT broadband
@randelld
DrayTek Vigor 2850n VDSL2 router
Configuration details provided by coolsparx, one of our forum members. Thank you.
Here are the ones I changed from factory defaults.
Disable WAN2 & WAN3
Enable WAN 1, rename to BT infinity, set to VDSL only
Enable VLAN tag insertion (VDSL), set tag value to 101 & priority 0
Modem settings (for ADSL only) multi-PVC channel 1, VPI 0, VCI 38, encapsulating type VC MUX, protocol PPPoE, modulation G. DMT
WAN connection detection mode ARP detect, MTU 1442
Service name left blank, username bthomehub@btbroadband.com, password bthomehub@btbroadband.com
