mispeltyuoth
Message 1 of 7
Confused about my internet connection
Hi All
I hope this is the right place for this query .............
I have a Smart Hub which I connect a number of devices to including a desktop PC via Powerline adapters. Recently, I've noticed that the internet icon in my taskbar is accompanied by a yellow triangle and 'No internet' is displayed below my SSID. Wifi is switched off and, if I go into the network adapter settings and view the connection status, they all say 'no network access'.
Where this is puzzling me is that I am able to access the internet (see below), although, my Office 365 Outlook won't connect nor will my VPN.
Please can anyone explain this?
If it's relevant, I'm running an HP EliteDesk 800 G" on W10 Pro.
Thanks in advance
6 REPLIES 6
Message 2 of 7
Re: Confused about my internet connection
It looks more like an issue with your PC wireless card turning off or going into power save mode, so its worth checking the power settings. I would also check to see if there are any updates to the wifi card drivers, on the HP website.
The pages you can still see, would be those that are stored within the web browser cache.
Message 3 of 7
from your post I am assuming that problem with no conenction only with pc - or with other devices as well?
if just pc have you tried conencting pc to hub with ethernet cable and missing out powerline adapter to see if that solves the problem?  suggesting maybe problem with powerline adapter
Message 4 of 7
Also check that you have not accidentally turned on the airplane mode via a function key.
Also look at the results you get from a Google search of "hp laptop wifi turns off by itself", there are a few solutions there.
Message 5 of 7
@Keith_Beddoe
the Hp is a desktop pc connected by powerline hence why wifi switched off - or at least what I read from initial post
Message 6 of 7
It was the bit " 'No internet' is displayed below my SSID" which implied a wifi connection.
mispeltyuoth
Message 7 of 7
Sorry about not responding - I've been away for the weekend. I'll try to answer your queries/clarify my OP
1 - what I can see isn't cached - I cleared the browser history before testing/posting
2 - I can't connect directly to the hub (too far away) but, to me, that's not realy the issue; it's that I seem to be able to browse the internet without an obvious connection of any kind!
3 - Flight mode is definitely switched off but again, how is it I can browse the internet
4 - It is a desktop PC but has wifi and ethernet connectivity.
Thanks for your comments, it looks as if I'll have to try HP - which should be educational if past experience is anything to go by!
