Message 1 of 4
Connect Canon MF3010 printer to my SmartHub 2 through USB port
Hello! I have successfully connected my printer to my SmartHub 2 but I can't find how setup it. In admin panel of SmartHub it says that Printer device connected but I can't understand how I can set up it on computer. I have MacBook Air 2020 with MacOs 12.1. Thank you in advance.
3 REPLIES 3
Message 2 of 4
Re: Connect Canon MF3010 printer to my SmartHub 2 through USB port
do you have any printer software on your mac ?
Message 3 of 4
I very much doubt it will work as a network printer connected to the USB port of the hub as the hub is not a print server.
Message 4 of 4
Go to system preferences - printers - add printer.
The printer should appear as available to add - probably as an Apple Bonjour service or possibly a Canon Service.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings icon. If someone answers your question correctly please let other members know by clicking on ’Mark as Accepted solution’
