emalrola
Message 1 of 1
Connect samsung ethernet printer to wifi disc using ethernet port on disc
I have just moved and we have wifi in every room via wifi disc.   I cannot get my Samsung printer to work though on the wifi disc - it needs an ethernet connection.  If I plug it into the hub using ethernet, it works, but if I plug it in to the wifi disc using ethernet, I cannot see it on the network.  Please advise whether this should work and if so, what I need to do to make it work?
