JennyV
Newbie
Message 1 of 2
Connecting a Smart Hub
Trying to set up my BT Smart Hub. The pack comes with one red cable and one yellow cable. The first step is to connect the hubs WAN port to the Openreach modems PORT1/LAN1 port. I am in a new build property and the modem does not appear to have a brand name or any labelled ports so I'm stuck.
1 REPLY 1
Message 2 of 2
Re: Connecting a Smart Hub
Welcome to this user forum.
Is this any help http://bt.custhelp.com/app/answers/detail/a_id/54651/~/connecting-and-set-up-of-your-bt-hub
and http://bt.custhelp.com/app/answers/detail/a_id/36968/~/how-is-fibre-to-the-home-installed%3F
You probably have an Openreach ONT. There should be a LAN port, but on the latest version, I think its under the bottom cover.
