Message 1 of 3
Connecting a USB hub to a Smart Hub 2?
When using a BT Smart Hub 2, can you connect a USB hub to it and connect several hard disk drives? Thanks.
2 REPLIES 2
Message 2 of 3
Re: Connecting a USB hub to a Smart Hub 2?
Try it and see. I suspect it will need to be a powered hub, I doubt the SH2 will have sufficient power to power multiple drives. It will certainly power a single drive though. You will need to enable SMB1 to use the usb port.
Message 3 of 3
Thanks.  I’ll be using a powered hub.  I’m trying to establish whether through the powered hub I will see all HD’s connected.
