Thuvboss419
Newbie
Message 1 of 2
Connecting wireless connection from Xbox 1s to by wifi extender 1200
1 REPLY 1
albertj
Message 2 of 2
Re: Connecting wireless connection from Xbox 1s to by wifi extender 1200
Hi @Thuvboss419
Welcome to the Community!
I believe this device gives the name EXT2/EXT5-[Original WiFi Name] to connect to. With the password being the same as the main WiFi.
So when you search for networks on your Xbox you want to look for these. Ideally, if there is a good signal you would want to go for EXT5 as this will be a faster signal.
Hope that helps
Please press the thumbs up if you found my response useful and mark it as a solution if I resolved your query.
