js246
Message 1 of 2
Connection Dropping
Hi - my broadband connection keeps dropping and reconnecting every few seconds. I’ve restarted the router and no improvement. Any ideas?
Using Whole Home with 3 disks (all have blue lights)
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Connection Dropping
Hi @js246,
It's good to see you back on the community. I'm sorry you're experiencing issues with your connection.
To help rule out any issue with your phone service please run a quiet line test by dialing 17070 from your BT Landline. If using a corded phone then the test should be quiet, if you are using a cordless phone then you may hear a low hum.
To help get an indication of where the problem is, please, can you post your router stats as shown here - Top Tips to get help on the forum
PaddyB
