ashleyglasgow
Message 1 of 4
Connection drops when downloading after upload problem fixed
Hi there,
As per title; my connection drops out when I download files. This immediately follows the resolution of the same problem but with uploads.
Any help would be appreciated.
Best,
Ash
3 REPLIES 3
Message 2 of 4
Re: Connection drops when downloading after upload problem fixed
Do you have a VDSL connection or a FTTP connection?
It may be worth trying a different router?
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Moderator
Moderator
Message 3 of 4
Hi @ashleyglasgow,
Thank you for posting back. I'm sorry you're connection is dropping when downloading. I can see that @NeilO had help you with the previous upload issue. I've let him know  that you're experiencing issues after that fix and he'll get this investigated.
PaddyB
Moderator
Moderator
Message 4 of 4
Hi @ashleyglasgow I called yesterday and sent you a private message as I missed you. The Hub team have checked and can't see any Hub connection drops over the last 6 days. Can you drop me a reply to let me know if this is still a problem?
