ashleyglasgow
Message 1 of 12
Connection drops when uploading more that 2-3gb
Hi all,
As per title, everything works swimmingly until I upload larger files, at which point the connection drops out until I restart my router.
After doing my research, it's suggested that the only place that anyone has any success in dealing with this issue is right here in the forums, apparently, its a setting on the router that needs adjusting but that can only be done from BT's end.
Any help would be greatly appreciated,
Ash
11 REPLIES 11
Message 2 of 12
Re: Connection drops when uploading more that 2-3gb
Welcome to this user forum. @ashleyglasgow
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Moderator
Moderator
Message 3 of 12
Hi @ashleyglasgow,
Welcome to the community and thank you for posting. I'm sorry your experiencing issues with your connection when uploading large file. What BT Home Hub are you using?
PaddyB
ashleyglasgow
Message 4 of 12
Hi PaddyB, thanks for replying.
The hub in question is a home hub 6.
Best,
Ash
Moderator
Moderator
Message 5 of 12
Hi @ashleyglasgow I've sent you a Private Message with details on how you can get in contact with the mod team and we'll request assistance from the Hub team.
Moderator
Moderator
Message 6 of 12
@ashleyglasgow Hi Ash, many thanks for sending over your details. I've raised a case with our Hub team to see if they can help and I'll get back in touch with you when they update me Smiley Happy
ashleyglasgow
Message 7 of 12
Thank you Neil.
Moderator
Moderator
Message 8 of 12
Hi @ashleyglasgow I've had and update back to say the Hub team have applied a fix to your Hub. Can you try uploading a large file and post back to let me know if this is sorted? Cheers.
ashleyglasgow
Message 9 of 12
Will do, thank you.
ashleyglasgow
Message 10 of 12
Everything seems to be working properly now, many thanks Niel.
Ash
