ashleyglasgow
Message 11 of 12
Re: Connection drops when uploading more that 2-3gb
*Neil, apologies!
Moderator
Moderator
Message 12 of 12
@ashleyglasgow That's brilliant, thanks for letting me know its sorted. If you need any help in the future you know where to find us Smiley Very Happy
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
