RoomClub
Newbie
Message 1 of 1
Connection drops with second BT router set as AP
Hi everyone,
I keep having connection drops using a BtHub5 as AccessPoint.
The first device I use is an older BtHub what works just fine, except for the WiFi connection.
So I decided to use a second BtHub that I had as AP.
I gave an IPaddress to the second BtHub from the first, and disabled DHCP on the second BtHub.
Following a guide I found online everything looked fine and working, but since the day after I started having connection drops.
Anyone that has a clue of what may be happening? Thanks!
