Scaniadriver57
Message 1 of 2
Connection problems
I have 3 ip cameras bought 4 bt 600 extenders all light up green 2 connect ok but the one in mums bedroom won't connect via ethernet but will on wifi can someone help please doing my head in
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Connection problems
Hi @Scaniadriver57  Welcome to the forum and thanks for posting.  Sorry you are having a problem with the broadband extender 600. Check out the help page Broadband Extender 600 and if you can't find the answer in the manual the contact information for the helpdesk is listed.
Cheers
John
