Cliffinkent
Message 1 of 11
Connection to SKY+ on demand fails connecting to BT HH6
Hey
I've recently switched to BT Infinity, using BT home hub 6. Since then I've been unable to connect to Sky on demand.
It detects my SSID, accepts my password, but the eonnection to the router and on demand shows up as "failed"
Had PlusNet fibre before with no problems whatsoever
Anyone else had this issue? Seems odd.
Thanks for your help!
10 REPLIES 10
Message 2 of 11
Re: Connection to SKY+ on demand fails connecting to BT HH6
Cliffinkent
Message 3 of 11
I'll give that a go when I get home tonight thanks!
Cliffinkent
Message 4 of 11
Ok
solution was 3 fold
1- separate the 2ghz and 5ghz frequenices
2- disable smart setup on the hub
3- manually enter the IP info on the sky box as per this post https://community.bt.com/t5/Connected-Devices-Other/BTHUB6-wireless-connection-to-Sky-on-demand-box/...
then reboot the the home hub
Poppy7
Message 5 of 11
@Cliffinkent wrote:
Ok
solution was 3 fold
Glad you've found a way to get Sky box connected again. Shouldn't really have to be doing all this though, should we. Have given our Smart Hub a not so smart new name now!
Poppy7
Message 6 of 11
Hub6 updated to the latest 2244 firmware last night. The Sky Box wasn't connected this morning even though I had put manual wifi settings into it in Oct to get On Demand to work.
I tried the wireless key on the off chance that the new firmware update might have fixed the connection problems and for the first time since the Oct firmware update that started the problem - it worked!
Distinguished Guru
Message 7 of 11
When my sister had issues with sky connecting. I set the router to a fixed wireless channel. Never had the problem again.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Poppy7
Message 8 of 11
Thanks for the suggestion, if it disconnects again I'll try and find out how to fix the wireless channels. Currently on 6 and 36 but haven't been taking a great deal of notice to see when they change.
jezthomp
Message 9 of 11
I'm not even getting an IP on my Sky box to connect directly 😞
Any ideas as this Smart Hub is not being that smart.
Distinguished Guru
Message 10 of 11
Assume you have a direct connection to the hub with an ethernet cable?
