keithwjones
Message 11 of 12
Re: Constant Resolving Host Issues - BT Home Hub 3
I bought a new router not HH which did not solve the problem.
Look at:
Click Here
Keith
Bal
Newbie
Message 12 of 12
The problem is probably not your router or your own set up.
Out situation miraclously cured itself on our HH3/ADSL installation and we now have Infinity too and things are more stable  - it seems like there is a probelm with DNS resolution at some node in the BT infrastructure that affects people in areas being upgraded.
If it persists then phone BT and try to talk to a human (quite likely that first and 2nd line support will struggle to see the problem but you might be lucky) and be persistent with hard facts and information to hand
