Craigecc
Message 11 of 23
Re: Constant drop in connection
Over a week and not one bit of help. Absolutely shocking. Because of our constant disconnections our speed is now at 17 down, not acceptable at all. I expect better from a huge company.
Anyone?
Message 12 of 23
Are you using the test socket with a filter to eliminate your internal wiring causing problems and also your faceplate
can you post current hub stats
this is a customer help customer forum as it says at outset and I like you am a customer just like you.  people will post if and when they want or not at all. There is no point in posting if they do not think they can help
your post does not go to BT
Craigecc
Message 13 of 23
Re: Constant drop in connectioin
I posted my stats when last asked (page 1), unable to currently post again as I'm at work.
Message 14 of 23
I saw your previous stats but looking for up to date stats if your connection is dropping as often as you say
Craigecc
Message 15 of 23
Will post them in the next 1.5 hours
Craigecc
Message 16 of 23
Product name: BT Home Hub
2. Serial number: +068343+NQ40316961
3. Firmware version: Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 30/06/17
4. Board version: BT Hub 5A
5. DSL uptime: 0 days, 11:06:58
6. Data rate: 19258 / 65687
7. Maximum data rate: 19258 / 78520
8. Noise margin: 6.0 / 6.0
9. Line attenuation: 12.6 / 11.2
10. Signal attenuation: 12.5 / 11.2
11. Data sent/received: 70.9 MB / 918.2 MB
12. Broadband username: bthomehub@btbroadband.com
13. BT Wi-fi: Yes
14. 2.4 GHz Wireless network/SSID: BTHub5-Z8ZW
15. 2.4 GHz Wireless connections: Enabled (802.11 b/g/n (up to 300 Mb/s))
16. 2.4 GHz Wireless security: WPA2
17. 2.4 GHz Wireless channel: 13
18. 5 GHz Wireless network/SSID: BTHub5-Z8ZW5ghz
19. 5 GHz Wireless connections: Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security: WPA2
21. 5 GHz Wireless channel: Automatic (Smart Wireless)
22. Firewall: Default
23. MAC Address: 34:8a:ae:93:45:98
24. Modulation: G.993.2 Annex B
25. Software variant: AA
26. Boot loader: 1.0.0
Craigecc
Message 17 of 23
I connected to the test socket last night, after 15/20 minutes I did a speed test and it came back at 60 down. Went to bed, woke up, 12 hour shift, come home and did another test, back down to 17 down
Message 18 of 23
So connecting to test socket significantly increased your connection speed and also increased attainable suggesting there is a problem with internal wiring or faceplate
sorry if speed dropped can you repost the stats to see what has happened. Is the 17mb you posted a connection speed or a download speed?
Craigecc
Message 19 of 23
17 download speed.
It did seem to be at a higher speed last night but as the stats display there was a disconnection around 12 hours ago. (still plugged into the test socket
Thanks for any help
Message 20 of 23
If download speed can you post current stats from hub. If still same as last posted set then line faster and more stable so now download problem not connection problem. Was download test done using Ethernet connected directly to hub?
