Message 1 of 3
Constant dropping of iPad to hub
I have recently had a new smart hub and infinity installed , however my iPad keeps dropping about every minute for about a second then relinks , however if I link via BT wifi with Fon , I do not have these problems but the speed I get is a quarter of the speed I get linked direct and is no better than standard broadband , is there anyway if stopping it constantly dropping via infinity
2 REPLIES 2
Expert
Message 2 of 3
Re: Constant dropping of iPad to hub
Have you split the WiFi networks? 2.4Ghz and 5Ghz? It’s probably dropping as it’s auto switching between them.
Message 3 of 3
did you disbale the smart setup - if not you should
then split the 2.4/5ghz networks and select channels manually
