Message 21 of 26
Re: Corner of one room has no wifi connection....Advice needed.
@copthis1 wrote:
From what they said I will receive three discs......hopefully this will stop my daughters whining.
That is normally a chargeable extra, at part of the BT Complete Wifi Guarantee. You may of course be getting it for free. Hopefully they will supply some returns bags, to send the unused stuff back.
Message 22 of 26
The representative acknowledged  my years of loyalty and said the whole offer was free of charge and that returning the incorrect items would also be free.
Message 23 of 26
Wow 😀
Returns are normally free anyway, as they supply a pre-paid label, and you simply take the items to your local Post Office. All stuff that BT send out these days, are just loaned anyway, and normally have to be returned.
Message 24 of 26
@copthis1
Is this now resolved?
Message 25 of 26
Yes, all installed FOC.....Three discs and an engineer visit has re-awoken the dead spots...............😁
Message 26 of 26
I have marked it as an accepted solution. Thanks for the update.
