jowie74
Newbie
Message 1 of 2
Creating a User-Defined Application on BT HomeHub 5
Hi,
I'm trying to get Back To My Mac working from my BT HomeHub 5. I've set up a new User Defined Application, and set up these ports:
TCP 5354-5354
UDP 4500-4500
UDP 5353-5353
UDP 500-500
Any 4488-4488
However, if I try to switch it on for one of my computers, it displays the message:
Conflict
The game or application you’ve selected conflicts with an application () you’ve already assigned to another device.
Please remove the other application or select the same device.
This is the only port forwarding application I've tried adding to any device. There are no other applications or games assigned to any other devices. I've tried rebooting the hub, but still no joy.
Any ideas? Thanks!
1 REPLY 1
Message 2 of 2
Re: Creating a User-Defined Application on BT HomeHub 5
Disable uPnP first.
This page should help.
Port forwarding problems
