mrgoldfish1
Message 1 of 11
Could someone confirm that DMZ doesn’t work on the home hub 6a, as I’ve tried putting my PlayStation in DMZ to get an open Nat and it seems to do nothing, any help would be appreciated.
10 REPLIES 10
Anonymous
Not applicable
Message 2 of 11
Re: DMZ
Not sure if it works or not on BT hubs but if it does you will need to restart the hub for it to take effect
mrgoldfish1
Message 3 of 11
Re: DMZ
I’ve tried a reboot but unfortunately still no joy. I’m getting a moderate NAT with various ports open. The home hub is ok for a basic router, but it’s quite annoying that I can’t seem to get an open NAT. It maybe a software bug because the option is there but it doesn’t seem to work.
Anonymous
Not applicable
Message 4 of 11
Re: DMZ
I believe it works on TP-Link routers if that's any help
NeilO
Moderator
Moderator
Message 5 of 11
Re: DMZ
Hi @mrgoldfish1, welcome to the community and thanks for posting have you also set up port forwarding for the game you're playing as this often resolves issues with the NAT type?
mrgoldfish1
Message 6 of 11
Re: DMZ
Yes I’ve tried the ports I’ve found online. The game I’m trying to get an open NAT is Call of Duty WW2.
mrgoldfish1
Message 7 of 11
Re: DMZ
I don’t really want to go and get a 3rd party router as I’m happy with the home hub - speed WiFi etc is fine. The NAT problem is my only issue.
NeilO
Moderator
Moderator
Message 8 of 11
Re: DMZ
@mrgoldfish1, Activision have a very useful guide on NAT issues that I'd recommend you check out.
mrgoldfish1
Message 9 of 11
Re: DMZ
Thank you buddy all sorted.
MarkG33
Message 10 of 11
Re: DMZ
Make sure UPNP extended security is off too as that can affect matchmaking/quality in games.
*This is my signature...it's a bit boring*
