Message 1 of 4
DNS NO IP
I have done a ipconfig on win 10 and get connection specific dns nothing listed
also nothing in the default gateway
if i try to connect it comes back with no ip address
How can i put this right?
Thank you
3 REPLIES 3
Anonymous
Not applicable
Message 2 of 4
Re: DNS NO IP
What are you trying to connect to & how?
Message 3 of 4
Re: DNS NO IP
Hi
when compter is up and running instead of the tv icon on bottom right on task bar saying connect to internet , i get the globe icon saying no internet.
I do a trouble shoot and get back
No valid ip configution and gateway not available,
I have done all the ipconfig things BUT still the same globe icon on bottom right
and get connection specific dns "nothing listed"
if i try to connect it comes back with no ip address and internet.
Reset router 3 times to default
thank you
Message 4 of 4
Re: DNS NO IP
This sounds as simple as you are not connecting to the router.  Either the WiFi details are not being accepted, or if you connect using a cable, then that cable between your PC and the router has gone bad (it happens).
Whole house, garden, garage and half the street covered by a Flint 4 - WiFi 7 router
