J4MES
Message 1 of 4
Why Wont BT allow us to set a custom DNS on the bt smart hub 6.
I have many uses for this Pi-Hole for example
3 REPLIES 3
licquorice
Message 2 of 4
Re: DNS
You can set custom DNS on your devices, you don't have to use the hub's DNS.
J4MES
Message 3 of 4
Re: DNS
Yes thanks,
Thats what im going to have to do, although i wish BT would allow us to change the DNS at router level on the home version like almost every other provider does.
martin_z
Message 4 of 4
Re: DNS
If you're using pi-hole as your DNS server, then just set it up to be the DHCP server as well.  DHCP on pi-hole will then dish out the ip addresses and the DNS server address which will be the pi-hole.  Your BT server may still be a DNS server, but it won't have any clients.
